I Have numerous parts stacked in the shed looking for a new home all are in very good condition, will negotiate on prices need this stuff gone ASAP so i can start my new project.
Postage: At buyers expense
Contact: Ben at [email protected]
Item 1: Okuyama Carbing Alloy Pedal Rest and Pedals.
Description: Brand New suitable for race car will fit all skylines R32,R33,R34
Price: $150
https://www.sau.com.au/forums/topic/396798-shed-clear-out-bits-of-everything/
Item 3: Bride Graduation Material
Description: Genuine Bride Fabric, great for doing Door cards and center console's to match seats measures (1500mm x 750mm)
Price: $150
Item 4: Genuine Bride Ergo II Leather Seats and Matching Floor Mats
Description: Like Brand new only used a couple of times they have seat rails for 350Z and the Floor mats are for 350Z as well will separate rails, mats if need be.
Price: $2200
Item 5: HKS GT3037 Turbo kit for 350Z or V35 Skyline VQ35DE Engine
Description: Brand New still in box never used full complete kit comes with everything.
Price: $3200
Item 6: OS Giken R3C Triple Plate Clutch for R32 and R33 Skylines/ GTR
Description: Used has done low km's still has plenty of meat left on it very nice street clutch for high power GTR's easy to use and super strong. Rated to 900hp +
Price: $1500
Item 8: Genuine Cusco Front and Rear Swaybars for R33 GTR will fit other models
Description: Used done low km's, heaps Thicker than standard ones comes with the different bushes and clamps
Price: $400
Item 9: Hankook RS3 Tyres
Description: Brand New 285/35 R18 x 2 super sticky street tyres tread wear rating 140 closest thing to a semi slick you can get.
Price: $500
hicas canceller - will it work on a 32R?
How's the pedal set attached?
Hicas canceler will not work on R32 only R33 and R34s
Pedals are attached with screws and bolts.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
