Hey all,
I have just upgraded my fuel system and intake manifold, so the following parts are no longer needed.
Power Enterprise 650cc injectors - $550. These are a direct plug and play injector for the RB25DET Neo, perfect for anyone looking for a simple solution to squirt more fuel in! I was making 393rwhp with these and they had plenty of room for more. I had them flow tested and ultrasonically cleaned before they went into my car and they have only done ~5000kms since then.You will need new O-Rings as the old ones were damaged when I removed them from my car. Easy and inexpensive to replace.
Stock RB25DET Neo injectors - $150 ono. I've had these since I installed the PE injectors. They're not doing me any good just sitting here, so may be useful to anyone needing to replace their injectors or turbocharging an NA motor or whatever. They were working perfectly when they came out, could probably do with a clean since they have been sitting around for awhile. Flick me an offer.
Stock throttle body and TCS module - $100 ono. Good condition, came off a motor with ~70xxxkms on the clock. Doesn't include throttle position sensor.
Stock intake plenum - $50. Just the plenum itself, excludes the stock runners as these are being used with my Plazmaman plenum. Also in good condition.
Stock fuel rail, fuel pressure regulator and top fuel dampener - $150 ono. All in very good working condition. I am happy to separate as well, so shoot me an offer if you are just after one of the parts, otherwise it's $150 ono for all of them.
Stock crossover intake pipe - $20? Make me an offer. Perhaps useful for people who need to get stickers off, etc.
Neo plastic engine cover - $50? Make an offer. Has been painted blue/white and modified to suit front mount intercooler piping.
Bracket for Neo engine cover - $15? Make an offer.
Stock RB25DET Neo blow off valve - $60. Works perfectly, no longer needed since I upgraded mine to a stock GTR item.
Stock GTR blow off valve - $80. Also works perfectly, I used to run the dual GTR bov setup but have since decided to just use the one, so this one is no longer needed.
Best way of contacting me is via PM or text message (phone number below). I tend not to answer calls from unknown numbers, so best to send me a message first. I'm on here often as well, so feel free to contact me here. If you want pictures of anything then send me a text and I'll try to get some for you asap, but otherwise they simply look like the stock items they are.
With regards to postage, I am happy to post Australia wide at the buyers expense. Not trying to rip anyone off, so just send me your postcode if you're interested and I'll get postage costs calculated for you.
Cheers,
Martin.
0431047984.
https://www.sau.com.au/forums/topic/396878-rb25det-neo-parts-and-stock-gtr-bov/
  • 2 years later...
Where are you located ?
You could have my stock throttle body and traction control unit for 50 + postage if not in Adelaide.
Whole cars only done 50 thousand so it's all squeaky clean and working etc.
Cheers, Brendan
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
