Fuel Pump Help
Ps1Locybe
 Share
Hi everyone
So i have just bought a r33 4 door of a close mate and not so long ago he had a bigger fuel pump put in as an " i owe you job " and ever since every now and then you will be able to hear the fuel pump whirring fairly loudly (i can hear it over the engine) although i usually hear it once i start slowing down and the engine is quiter.
Every now and then it will cause the pump to surge but usually you wouldnt hear the fuel pump or have it surge and it would only make the whirring noise and surge when i was running on a low tank of fuel but i have noticed it does it every now and then regardless if how much fuel is in the tank.
Does anyone know what i can do to fix this?
Should i just get a stock fuel pump?
Any help is greatly appreciated
Ps1Locybe
I actually ment to write:
It doesn't always make the sound or surge it usually did it on a low tank but now its doing it randomly regardless of howmuch fuel is in the tank.
P.S my mate said the fuel pump was getting air pockets in the lines causing it to surge or something.
Once again any help is greatly appreciated
Ok so do you think i should try refitt the current fuel pump myself or get a proffesional to do it or should i just get a stock fuel pump?
Sorry im not very mechanicly minded but im prepared to try anything myself
  • 2 months later...
It will even make this whirring sound when i am on over half a tank of fuel, i am beginning to think the bigger fuel pump is moving uneeded fuel around causing it to heat up and thats when i can hear the pump, it also has trouble starting up sometimes, i have found that if i turn the key and listen for the fuel pump and try start the car before the fuel pump finished pumping fuel it will start fine but if it finishes pumping then i attempt to start it will struggle and i usually need to give it some gas to help it start, which i shouldn't being an automatic transmission.
Im also thinking a fuel pressure regulator might fix this problem but what us everyones thoughts?
Really need some help on this guys?
Ps1Locybe
I don't think i have a fuel pressure regulator that im aware of? I ment should i get one?
Sorry im not very mechanicly minded and i bought this car of a friend not long ago so i dont have a very detailed understanding of what happened with the fuel pump, when i asked him in a message he replied:
aw it's like equivalent to a Bosch 040 or a 044 some thin like that it's a decent one.
So i guess im going to have to find out for sure exactly what pump it is and if its properly wired to the battery first?
What can i do if i cant find out solud details?
We need more information to help you, what pump is it? Has it been wired to battery voltage like all aftermarket pumps should be?
noob question but why do aftermarket pumps require this? and is it applicable to Tomei and nismo pumps too?
Factory setup switches between 6V and 12V, 6V at idle/low load and 12V for higher load. Aftermarket pumps don't like 6V, and don't perform very well at 12V (infact might be worse than the factory pump). It's only when aftermarket pumps are running at alternator voltage will they deliver what they advertise (255lph for walbro pumps etc)
Yes, run the old pump power wire to a relay and switch constant power (fused) from the battery with decent sized wire. Don't forget to do the negative side as well, I run that back to the battery also.
 Share
    • Stock R33 boost control, with the exhaust, and FMIC done, will boost creep. There is no tuning around it if it is the factory boost solenoid.   If it has an aftermarket electronic boost controller, the settings/mapping can be altered in it.   Oil could be anything as mentioned, however did it ever do it before you did the turbo swap? How much and how often did you drive the car before the swap?   I'm hinging on too much oil supply, or it's not draining properly.   To check, pull the air outlet off the turbo. Is it full of oil? Drop the exhaust at the turbo, does it appears to be oiled/coked? Now pull turbo and check the exhaust manifold, does it appears oiled and coked the same way?   Secondly, the PCV could even be stuffed / not functioning properly and will cause blowing of blue smoke.
    • Almost any ECU would work, from a 30 yr old PowerFC to a new Motec/Autronic. But presumably you want new middle of the road ECU, meaning that you want a Haltech or a Link, most likely. As to which model though? I dunno. I don't keep track of what they have in their current ranges. You don't want a plug in though, because plug ins can start to cause you the same wiring issues that you have to chase up with your stock ECU/loom swaps when an engine transplant is involved. If you use a Haltech (and presumably a Link) you could put the base map for the engine in and drive it around and not even need to "tune" it. It will work just fine. I can't recommend a tuner without a location (and even then I can't recommend many, being as I never use any tuners except myself and my brother-in-law). And not many tuners are happy to remote tune. Maybe they'd be happier doing it for a basically stock setup that just needs to be demonstrated to be working properly. But even then, not being able to be with the car to see what the hell is going on and sort out the inevitable problems that will result from an engine conversion done by an amateur..... unlikely to be enthusiastic about the job. And if you think that just adding 2 wires for the boost sensor is difficult - you don't want to be trying to install and set up an aftermarket ECU. You're going to have to bite down hard on something with either approach.
    • wired everything up and confirmed that the red with white stripe is indeed the fuel pump pin on this harness.
