Just like to know what turbos you people have in your skylines? What do you think is the best low-mount turbo for a rb25det. I have been told the best for a street application would be the HKS GT2535. What are your oppinions? Does this turbo bolt straight on, if not what do i have to do to get it in? Looking forward to your reply's. Thanks!!!
https://www.sau.com.au/forums/topic/39741-aftermarket-turbos/
hrmm, i think either one is sufficient for the amount of power you want to make... i would consult a turbo specialist on what the best turbo set up for your price range is.
i am just talking from experience with my friends Hiflowed T3, that worked a treat.
Hopefully someone with a 2535 will comment on that turbo and its advantages! =)
I have an HKS 2535. Just got it put on. Had fuelling problems when i went to the dyno so couldn't wind past 7psi but was getting 180rwkw at that boost level. Have just received my adjustable fuel pressure regulator and expecting a Z32 AFM and will post results when i get them. I have wound the boost up to 1.1 bar and it hits that by 3,300 rpm and pulls very nicely indeed. I hit boost cut at 1.15 bar at about 4,000rpm the other day which is my airflow meter maxing out at 5v which on an R33 happens about 220rwkw so this turbo should easily see you to your desired power level.
As for installation, it bolts straight on to your exhaust manifold, dump pipe, AFM pipe and with the supplied elbow, to your intercooler pipe too. I got the GT Sports Turbine Kit which came with braided hose for the oil line and new replacement piping for the water lines. Hope that helps.
oh, you wanted mods too...
When I finally get my power run again I will have:
Trust FMIC, Z32 AFM, Bosch 910 fuel pump, Nismo adjustable FPR, full exhaust, Trust Ex Cam Gear, S-AFCII, Blitz EBC and rebuilt engine with forged pistons.
you should be fine, so long as your engine has sufficient compression and when your running 12psi it isnt leaning out/detonating etc...
invest in a dyno tune from somewhere that is renouned for tuning properly.
Reliability is the key!
Nothing sh1ts me more than when someone tells me they have 200+ rwkw and have their standard injectors maxed out etc etc. Thats just not cricket.
Exactly!!! I will have a power FC so as far as that goes it can be tuned accordingly. I hate when i go to shops (no names) and the guys there tell me that i can get easily 270 rwkw from my standard engine without problems. I think that is total crap! Can do it but it will probably last about 2 months or so, then the problems will arise. Anyone here have that kind of power with standard internals? Just like to hear about it?
i am attempting to put on a t3/t4-super t 70 on mine all i can say it is ***ing huge 1700 it cost brand newcop a look at the specs.....shaft and wheel trim64.5 mm -compressor wheel super70 60.5mm -turbine housinga/r84.-compressor housinga/rratio.70... supposed to be capable of 650 hp can any one who knows what they are doing tell me the go and what mods/ lag ect i will expect
Your engine will last with 270rwkw on standard internals, I know of several cars that have lasted over 6mths each after being very heavily murdered with much more than 270rwkw. It all depends on your tune :rant:
Guest INASNT
Your engine will last with 270rwkw on standard internals, I know of several cars that have lasted over 6mths each after being very heavily murdered with much more than 270rwkw. It all depends on your tune :)
It depends on the tune and how u drive. If u drive like a tool all the time at full throttle then ur engine wont live long.
Mine has lived with over 300rwkw high boost and 260rwkw low boost for about 2 months now without any problems.
Fuel seems to be the problem IMHO. Alot of people try and stretch the stock injectors to places they just werent meant to go. All that I know of who upgrade the injectors and dont chase every last kw, have had no dramas.
Personally I wouldnt really want to chance it (well I didnt chance it). If you upgrade the injectors as you fit a bigger turbo you will be safe - with a good tune. Cheaper than a rebuild - infact cheaper than a set of forgies:)
I have over 300 in a daily driven RB25, running over 20psi no problems - stock internals. the JMS R33 had over 300rwkw with stock bottom end too, and that gets caned - still going strong.
I want to do everything properly, no short cuts. What would be the best size injectors for this application? Where do you suggest to get the car tuned at? I heard that Croydon Racing is the best but they charge an arm and a leg! I think it was like $700! Any other good places?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
