hey all, i currently have
pioneer DEH P3550MP h/u, 50x4 mosfet
Boss BA-1000 amp, 4ch 1000w peak
4" speaker in the front
6x9's in the back
Pioneer TSW305C 12" sub in pioneer box
the amp is running 2ch to the sub and 1ch to each 6x9
what i would like to know is, if i ran my sub soley off my boss amp and got another amp (75rms x 4ch) to run all my speakers, would it be benificial? i am getting this amp for $20 tonight, if its not going to help my sound quality/performance i will just sell it...
is it worth doing or a waste of time?
https://www.sau.com.au/forums/topic/39746-adding-an-amp/
i read that my boss amp was 4x75 and i found out that my other one is 4x70...i picked em up cheap so it dont really bother me...
plus if i run 2ch off the boss amp to the sub, i can run it at 2ohms and ot will be more powerful (its 2ohm stable apparently)
i think your just tellin me to sell my boss amp coz boss have a bad name, this amp isnt actually that bad and does the job well...
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-820214
Why do people have an obsession with subwoofers?????
imho,
1. throw out the 4 inch speakers. 4 inch speakers are good for nothing. Replace them with some decent quality 6 inch splits. This will make the biggest difference to your overall sound quality. That is if you are interested in quality. If all you want is distortion and doof doof, then keep it te way it is set up atm.
2. Amp up the splits in the front doors with the other two cannels of your existing amp. run the 6x9's off the head deck. Or alternately disconnect them altogether. I think you'll be surprised that less speakers sometimes sounds better.
basically what nav2k said.
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821505
i am looking for good 6" splits but cant any that i think are good enough...i havnt had a big look though...i saw some pioneer splits...but they were $329, so i said no.
as soon as i get the splits i will hook the amp up to them as that is what many people recommend, but until then, anything that is better than current is good!
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821716
Also something you might want to consider (after you get splits) is putting capacitors on your 6x9's, as I have found that 6x9's AND a subwoofer in conjunction often leaves you with very muddled sounding bass. On mine I just put capacitors on the 6" speakers on my back dash to filter out the bass (I aslo have a JL 10" running at 240watts rms) And I am well pleased with the result.
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821974
anyways, back to the topic...
if i put in my 4x70 amp and hook it up to each speaker it will go a lil better i spose.
but my prob is, how do i make my 4ch amp dedicated to the sub? if i just bridge 2ch will the other 2 burn out or will i just be losing power? is there any way o bridge 4ch into 1 or will a hear a big boom (from sub blowing that is)?
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-830763
    • Wrt the engine, you're very much limited by 'production quality' as to how much extra power you can extract from them (I'm talking i6 red-motor) -- a lot here depends on how 'authentic' or 'period correct' you want the modifications to be... ...I'm too old... <grin>...the first true performance engine Holden made, was in the HD/HR models ~ this was the 'X2' performance pack...it came with twin downdraft strombergs on an otherwise unimproved intake manifold, with a two piece exhaust manifold (reckoned to be as good as extractors)... ....these engines were built upon the '179HP' cylinder block, which included extra webbing in the casting to make it stronger and less susceptible to block distortion... The next performance i6 came out with the HK Monaro (also found it's way into the LJ GTR Torana ... the car I wish I hadn't sold)...it had pretty much the same manifold setup, but was built against the '186S' block...this block retained all the extra webbing of the 179HP block, but added a forged steel crankshaft (instead of the stock cast crankshaft), because it was possible to snap the crank... ...apart from the inherent weaknesses in the stock (cast crank) blocks, the next limiting factor is the cylinder head porting & combustion chamber design, and the actual valve sizes. Back in the day, you could buy a 'yella terra' cylinder head (from stage 1 to stage 5 gradients), and this was the way to get serious power out of them -- with the extra breathing of these heads, you could fit a triple SU or DCOE Weber setup... ...obviously, these mods were a waste of time on a stock cylinder head/camshaft grind. My housemate rebuilt the i6 in his VH dunnydore about 6 months back -- this is a 186S block with the 12port 2850 blue motor head and intake/exhaust manifolds, with a dual throat Weber off an XF Falcon mounted on an adapter plate ; it's not a bad makeup...got more torque & fuel economy just light-footing it about on the first throat, but stand on it and it makes more giddy-up than the standard 2850 blue motor that it replaced. Personal note: I'd just fit an RB30 and be done it it 馃槂
    • Thanks for sharing. That's a great video! My buddy is doing the same thing on his build (S chassis struts and towers). He's building an S14 with billet RB30 shooting for 2000whp... a race car with a TH400 just like this video. For a road car I just couldn't go this route as the strut has to be almost vertical and the caster is not going to pivot correctly (let alone camber gain). You think the R32 frontend is bad, wait till you put a MacPherson strut on without modeling it all in Solidworks to check geometry. I'm not saying it's a bad way to do it but I'd be really curious to see how it affects the geometry.
    • Hey Christof and welcome!  Sounds like an awesome project! I'm not sure many of the regular users on here would know much about the HK but I could be wrong.  Looking forward to updates.
    • As long as its NOT a HyperSHITtune, youll be fine.
    • First time visitor and currently getting ready to start work on my HK Premier.  Its all stock, 186 with 3 on the tree.  The only mod i have right now is extractors.  I am hoping to get some guidance on slightly modifying the engine to bring a little more power. Just going for a nice, comfortable cruiser.  The car is very straight, however i have been out of the country for 20 years and its been gathering dust at a family farm.  Will be doing quite a bit of body work to cut out some small rust areas (frnt quarter panels and a few other small bits) and fix up the paint.  Will be redoing the interior (its currently black and the seats are in real need of recovering and respringing the driver side (its front bench seat).  The dash needs a little TLC, but no real damage.  As my heater has degraded I am considering fitting something after-market that will be both heater/AC (recommendations here are always welcome). Wanting something discrete that will allow me to use the same controls and not be obvious once inside the car.   For the engine, i have been told i could consider upgrading my cam (imagine i would need a new head as well) and putting a new carby (currently the original stromberg).  However not sure what is going to be the best route.  Would certainly welcome any comments/suggestions.  As  a final step I am looking at changing the wheels. Current hubcaps are in dire need of refurbishment or replacement (imagine its a bit like hens teeth).  Thinking of some clean/classic looking mags (7-inch should be more than enough - not going for a large change in look).  Welcome any comments/advice and of course any questions.
