hey all, i currently have
pioneer DEH P3550MP h/u, 50x4 mosfet
Boss BA-1000 amp, 4ch 1000w peak
4" speaker in the front
6x9's in the back
Pioneer TSW305C 12" sub in pioneer box
the amp is running 2ch to the sub and 1ch to each 6x9
what i would like to know is, if i ran my sub soley off my boss amp and got another amp (75rms x 4ch) to run all my speakers, would it be benificial? i am getting this amp for $20 tonight, if its not going to help my sound quality/performance i will just sell it...
is it worth doing or a waste of time?
https://www.sau.com.au/forums/topic/39746-adding-an-amp/
i read that my boss amp was 4x75 and i found out that my other one is 4x70...i picked em up cheap so it dont really bother me...
plus if i run 2ch off the boss amp to the sub, i can run it at 2ohms and ot will be more powerful (its 2ohm stable apparently)
i think your just tellin me to sell my boss amp coz boss have a bad name, this amp isnt actually that bad and does the job well...
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-820214
Why do people have an obsession with subwoofers?????
imho,
1. throw out the 4 inch speakers. 4 inch speakers are good for nothing. Replace them with some decent quality 6 inch splits. This will make the biggest difference to your overall sound quality. That is if you are interested in quality. If all you want is distortion and doof doof, then keep it te way it is set up atm.
2. Amp up the splits in the front doors with the other two cannels of your existing amp. run the 6x9's off the head deck. Or alternately disconnect them altogether. I think you'll be surprised that less speakers sometimes sounds better.
basically what nav2k said.
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821505
i am looking for good 6" splits but cant any that i think are good enough...i havnt had a big look though...i saw some pioneer splits...but they were $329, so i said no.
as soon as i get the splits i will hook the amp up to them as that is what many people recommend, but until then, anything that is better than current is good!
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821716
Also something you might want to consider (after you get splits) is putting capacitors on your 6x9's, as I have found that 6x9's AND a subwoofer in conjunction often leaves you with very muddled sounding bass. On mine I just put capacitors on the 6" speakers on my back dash to filter out the bass (I aslo have a JL 10" running at 240watts rms) And I am well pleased with the result.
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-821974
anyways, back to the topic...
if i put in my 4x70 amp and hook it up to each speaker it will go a lil better i spose.
but my prob is, how do i make my 4ch amp dedicated to the sub? if i just bridge 2ch will the other 2 burn out or will i just be losing power? is there any way o bridge 4ch into 1 or will a hear a big boom (from sub blowing that is)?
https://www.sau.com.au/forums/topic/39746-adding-an-amp/#findComment-830763
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
