Hi all,
For sale is my 1997 R33 Series II. The car makes a very reliable and torquey 260rwkw and 430nm at 19psi and is an ex HPI feature car. The car has been in a collision and does not have a RWC but is easily repairable but that is simply not something i want to pursue at this time. The car is located in Dulwich Hill in Sydneys Inner West and i can be contacted on 0422 579 305, [email protected] or by PM. The car is manual and has 125,9xx Kms on the clock.
6]
I am asking $9900 as is.
I will try to be as detailed, open and honest about the car and am open to offers. Now for the good, the bad and the ugly:
THE GOOD
Exterior:
"v1 aero set" by topstage melbourne
nismo smoked side indicators
Work Emotion CR Kai 18x9.5 +38 all round, running 245/40 yokohama advan A13 front and 275/35 Nitto NT555 rear.
Roof painted black
Carbon D wing
Vented carbon bonnet w/ aerocatch locking bonnet pins.
Rear Gts-25t badge removed
Nismo carbon pillar garnishes
Skylines Australia and tunehouse stickers :D
(Photos with old wheels on)
Suspension/braking:
Standard calipers over dba 4000 slotted rotors, project Mu HC+ pads front, QFM rear
Tein Super street coilovers (J-spec)
Interior:
Bride Vios III drivers seat on bride super low rail
Bride Ergo II passenger seat on modified universal slide rail
(yes both the seats are genuine)
Navman c60 moulded into dash in place of ashtray/cigarette lighter (see the bad section)
Blitz Gearknob
CAMS approved fire extinguisher
Autometer 2" boost guage on steering column
Jvc head unit
Rockford Fosgate 6.5" splits front
Rockford Fosgate 6.5" coaxials rear
4 channel sony amp mounted beside battery (b/w boot and rear seat)
Twin immobilisers with keypad start
Engine:
Apex power intake in custom airbox
Greddy profec BSpecII EBC - Unit hidden in Glovebox (i only use one boost setting anyway)
z32 AFM
Garret GT3067R with 0.70 rear housing (internally gated)
Nismo 555cc injectors
Nismo adjsutable fuel pressure reg
Tomei in-tank fuel pump
600x300x76 B&P FMIC
GFB stealth FX BOV
Plazaman plenum
Splitfire coilpacks
Stainless dump
Stainless cat
HKS super drager 3.5" turbo back exhaust
2000ft/lb pressure plate gripping 5puck cushion button nissan patrol clutch plate (Custom clutch Tunehouse have made)
Apexi Power FC (hand controller in glovebox)
oil catch can
THE BAD
The car was broken into. This resulted in the GPS being stolen (leaving an empty space where the ashtray / gps once was), the left mirror being replaced with a black mirror and the below damage to the left A pillar:
The left rear rim has approx 5 inches of gutter rash:
THE UGLY
I was stationary at a T intersection and was hit at approx 25km/h from the right. The other car hit the front bar side on. The wheel and quarter panel were not hit. The chassis rails were not bent. The car does start and run but I did not run it for more than a 10 second test as the radiator fan is jammed into its shroud. I have been quoted by two smash repairers at 1500-2000$ to replace the radiator support and paint the new rad support and bar white. Over the past couple of months i have collected the parts required to repair the car and these are included in the sale.
-The Right front headlight needs replacing: The car comes with a new RHS headlight included
-The front bar needs replacing: The car comes with an R33 sedan front bar in pearl white
-The front bar REO needs replacing: The car comes with a bar reo
-The radiator support needs replacing: The car comes with a BRAND NEW GENUINE NISSAN radiator support in black
-The FMIC needs replacing: The car comes with a cooling pro stealth series (black) 600x300x76 bar and plate cooler
-The front bar will need a new grill: The car comes with a new grill sprayed in white.
-The car will need an oil change: The car comes with 5L of Motul 4100 and an oil filter
-The carbon bonnet is broken and will need replacing - The car comes with the standard white bonnet included, however the white bonnet has a scratch in it.
I am open to any questions and offers you may have.
Again, 0422 579 305 and [email protected] are preferred contact however i can be reached via PM.
Cheers,
Sean
https://www.sau.com.au/forums/topic/397517-1997-r33-sii-260rwkw-9900/
very sad mate and a quick way to see a lot of hard earned money disappear. Bowing out for now; youve seen how much i spent on this car...can't do that again right now.
Not willing to part out at this point sorry. Car is priced such that if someone has the time and the room to part it out they can buy the whole thing and part it for profit and I wouldn't mind at all.
PMs replied to.
Ive now had offers on:
Airbox and filter
plenum
injectors
fuel reg
turbo
AFM
BOV
fuel pump
power FC
boost controller
catch can
anyone else want me to make offers on any parts?
Airbox and filter
plenum
injectors
fuel reg
turbo
AFM
BOV
fuel pump
power FC
boost controller
catch can
sold. now open to anyone wanting parts. will post a thread in the parts section and link to it here when im home.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
