Hey guys , thought id share my 2 pak painting experience to possibly help any others wanting to give it a go that are a little less informed.
so after purchasing my body kit i was up and down weather to get it proffesionally sprayed or to do it myself . after enough searching and and hearing the same price figures i thought id give it a go myself .
i have had previous experience spraying with acrylic with a few of my cars , but i thought i really want to step it up with this car and get the best finish possible , hearing enough talk about how 2 pak is obviously a more harder , stronger finish , i thought it was time to see it for my own eyes. spraying acylic in the past , i wasnt very happy with how easy it can dry out or even if you get petrol on it when filling it up , it could take off the shine.
i purchased all my paint , sand paper , and all neccesary items . as everyone has said , its all in the prep . i spent 2 full days fitting the kit , and preping all the panels for spray . i must say my fingers have seen better days with all the sanding , being in the furniture trade sanding is my worst enemy .
from this experience and other past journeys with spraying , i did definitly put a lot more effort in prep , and i can definitly say , spraying a guide coat / dust coat on the panels in black for the final wet sand was the best thing iv done, as it really shows up all the potential marks or spots you may have missed , which iv definitly learnt gives the best spraying surface , which is probably why my fingers are pretty sore .
i primed everything that was in gel coat , then wet sanded to 800 grit . sprayed 3 coats of base , followed by 3 coats of clear. i sprayed everything at home in the shed , even though your ment to use a spray booth , i feel i had everything set up pretty well.
i sprayed my front bar , skirts , rear lip , spoiler , rear bumper and bonnet on the way. here are my results , i know pictures can only show so much , but i was pretty damn impressed with how glossy it came out off the gun - and very hard , i havent cut anything back yet which i will do in a weeks time when its cured . i wiped the whole car down with wax and grease remover , so the shell does look dry at the moment until i cut it back and wax
any questions , please shoot , willing to shed the light for any others wanting to do it :)
cheers man , i like how the clear just really seams to water out once it sprayed . i did notice it will hide any ripples if you had them , as you build the clear up it seams to become more uniform during each coat.
i never wore anything when i sprayed arylic . but yeah i wore a full body suit to cover up and a propper respirator , i didnt want to take any chances . the stuff smells so strong .
Great work, well done for having a crack! It amazing what you can pull by getting in and having a crack!
I need inspiration like what you've done as I'm in the process of having my first go at fibreglassing up my cracked front and rear bars. Next step is obviously painting so thanks for the motivation! Only problem is you made it sound a lot bloody easier than it is!
i find confidence is the key , i used to be so worried when i used to spray acrylic , thinking oh damn i hope i dont ruin it etc....
a positive approach goes a long way . if you have everything correct , mix your paint to the right ratios , correct air pressure , and just test your gun settings on an old panel , you shouldnt have any trouble.
i did my bonnet yesterday , and i must say it came out great , no tiger strips either which i would usually get with acrylic in the past..
a little more motivational pics for those out there :)
Edited by sky017
You did end up doing it yourself!! That looks awesome mate!! I fixed up that front bar I got off you, and it's a bit rough but looks good! Just gotta figure out the mounting of it to fit as its not 100% perfect fit, ironically I destroyed my factory bar last night along with my fog light, ( guardrails hurt) but damn! Ur cars making mine look like a piece of shit! Looks really really good! Congrats!!
oh hey mate , yes ended up DIY , which was the best decision .
yeah how did you go with the fibreglassing ? did you end up tackling it your self. geez mate what did you do to your front bar and fog lights.
hehe yeah shes definitly an eye catcher now :) if you need a hand with the front bar fitting hit me up mate.
looks sweet man, ive done a few shed jobs with acrylic before and have always been pretty happy with the turnout.
DIY best thing u can do, worst case is u stuff it up and you start sanding again lol
haha , well i can definitly say i will never be touching acrylic ever again :P . practice makes perfect , but in saying that its hard to visualise the end product when you have to sand for a few good hours , hate it lol the skin on my fingers are just recovering.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
