Dads turbo diesel landcruiser has been towing 1600kg boat for years, nothin wrong with it and it loves it, hes running big front mount, 3 inch turbo back exhaust and 13psi boost. If ya ever see a red landcruiser with an autometer boost gauge on the a pillar thats my old mans.
Turboed vehicles are usually the best towers as well as they make decent torque for pulling. Remember that it will be the an auto box that will fry first before a turbo. Manuals rock.
https://www.sau.com.au/forums/topic/39781-loading-turbo/#findComment-812343
