I have decided to put one of my GTRs on the market. It is a 1990, factory dark blue. Receipts for new clutch and slotted brake rotors. New nismo engine and gear box mounts, white line camber bushes, new ball joints, AC recently serviced, engine rebuilt in Japan at some stage. It has 1.5mm os pistons, hks ssqv bov x2 with plum back fittings, apexi avc-r booster controller, n1bar inserts, polished r33 gtr rims. Tien adjustable coil overs, cyclops alarm with immobiliser, pivot turbo timer. Needs some paintwork as paint on the bonnet and one guard is starting to peel. Clean interier, no dash bubble, engine recently serviced with motul 300 v oil. rear diff bush needs replacing, will supply new bushes. Small amount of rust in bottom of rear guards. Car is not perfect but not too bad either.
$9,500.00. Ring Richard on 0416074843 with any questions.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/
I think you priced this very well. :thumbsup:
Its not bad for 1990 car. All it needs is love. At the price someone could buy it get it repainted and it will be immaculate I reckon.
Oh and some TLC with the interior
Edited by eat_me
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6321725
price drop $8900 i can make it cheeper depending on how you want it ,32 ,33 wheels no rego etc happy to drop it off at transport depo.A good cheep GTR that you can drive now.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6336880
yeah mate this is very cheap.. if you're not in a rush keep your price firm.. 8900 in that condition is a steal without any wheels haha.. my housemate here in Perth might be interested, will let you know
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6337471
How low can we go ? $7900 with a set of s15 sylvia wheels with worn tyres and no rego.Its a good driving GTR not a project, that only needs a small amount of work or just drive it the way it is.
https://www.sau.com.au/forums/topic/397901-r32-gtr-1990/#findComment-6344964
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
