Im looking at getting some of these for the car, has anyone used them, which ones, and do or dont you need aftermarket gauges or are they free standing (if you know what I mean)
http://www.summitracing.com/search/Brand/Longacre-Racing-Products/Product-Line/Longacre-Gagelites-Warning-Light-Kits/?autoview=SKU
Thanks for your help and information, Mark.
You dont need a guage, just somewhere to fit the sender
I would look at just the adjustabke oil pressure one
Just a heads up, as much as I love Summit racing, they will rape you on postage
Have a look at jegs.com, should have the same stuff but much better postage rates to Aus
Couldn't find any on Jegs, will be having a good look around though, but even with the extra delivery they are still well cheaper than buying from Australia.
I ended up getting a adjustable oil pressure and a oil temp warning light, ended up about $25 each.
Final price including delivery for 2 warning lights was $86.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
