Hi all, I am going to move on from the rb's so I will be clearing out all my gear, I will update the list as I go.
  • R32 gtr rb26dett complete engine package, has a mines stage 3 upgrade. Engine runs great has good compression and can be tested for buyers. Included with sale of engine twin HKS low mount turbos, HKS cast dump pipes, trust front pipe, Mines afm's, silicone cooler pipes & factory BOV's nismo 600cc injectors mines ecu tuned for package $4500.00 can be heard running turbos are 2510's or 2530's not sure but has 2530 on gold plaque on the ecu..
  • gearbox for above engine from r32 gtr (push type clutch) $500.00
  • 100mm gtr intercooler good condition some bent fins etc $250.00
  • HKS twin2835 high mount kit with 60mm wastegates may seperate manifolds, turbos & gates etc compressor wheels need replacing on turbos. Would sell complete for $3000.00 or seperate if I have buyers for all parts 1st. gates-$650ea manifolds with balance pipe-$1100.00 Turbos-$700ea
  • Huge GCG drag wastegate 65mm vband type new never used cost ove 1k will sell $800.00
  • z32 tt lsd diff $300
  • R33 gtst lsd $150
  • r32 gtr master cyl $120
  • R32 gtr clutch booster & master $120
  • R32 gtr abs module $100
  • R33 gtst radiator $75
  • R33 gtst turbo (leaking seals) $100
  • R32/33 power fc & hand controller $700
  • Sard 720cc gtr injectors $600
  • Gtr rb26 rwd sump $250
PM for pics pick up in Brisbane I will post at your cost on smaller items.
https://www.sau.com.au/forums/topic/398313-time-to-clear-my-garage/
I have a few PM's requesting parts from the engine package, I will seperate parts if I have buyers for turbos, afms, dumps & front pipe. Feel free to make an offer on any items. That said I have more to add.
  • RB25 ser2 head 79k's $400 (complete head)
  • Stagea rear diff (auto) $50
  • Stagea sump front diff (auto) $100
  • AWD rb25 short block from stagea $400
  • R32 gtr stearing column with key $120
  • 5 stud hub conversion $450
  • lexus 1uzfe v8 engine & harness $950
  • RB25 ser2 yellow jacket coils $250
There will be more to come feel free to ask if you are searching for something I have heaps to clear.
Edited by rb30dett
What shaft play is on the turbos?
Can you identify them? If they are HKS2530's i may be interested.
What is the engines internal specs and condition?
Hey mate, willing to pull the yoke off the 50 dollar stagea diff and send to adelaide? please! need one asap, thanks
Yeah mate it will cost ya$50+ post pm for bank details
There is no play also only selling complete at this stage, I will seperate if all bolt-ons sell or long engine sells first. Don't know what they are until the engine is out sorry. They have HKS cast into the compressor covers is all I can see.
Hey mate what is the condition of the yellow jackets? How old?
To be honest I don't know how old they are, they were on my rb25 when I bought the car it ran fine but I had splitfires sitting in the shed so I swapped them over on the 1st plug change. I can send you a pic if you want? They have not been used in over a year.
Also deposit taken on engine package. Please no more pm's about splitting the package thanks.
The RB25 Series 2 head, is this the later 97 model one with the Cas sensor change (series 1 is silver, late series 2 is black same as r34) ?
if the silver cas ill take it :)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
