----R31----
Front Grill - $30
Tail Piece - $50
Hood Lining - $30
sun visors, centre light, and all mouldings also available
Rear Bumper and Lip - $50
Set of all four door trims - $100
R31 clutch master - $50
Stripping the entire car as is only used as a paddock basher. Let me know if you need any other parts and we can sort something out
----VL----
S1 rb30 long motor - $50
- was running alright before being pulled out, suit rebuild or for some skids. comes with hand polished rocker cover
S2 rb30 long motor - $50
- wasnt running when removed, suit rebuild only
Mf5 manual box - $300 - comes with free standard clutch
Vl 2.5 inch exhaust - $50 - 2.5inch cat back, though rear muffler missing
Rb30 n/a auto - $50
2 x Vl front nose cones - $30 each
Vl auto pedal box - $30
Vl clear rear tail lights - $50
Vl head lights - $30
Rb30 extractors - $50
----RB20 and Rb25 parts ----
Rb25 S2 air flow meter - $100
Rb25 front face plenum - $100
has little crack in the base that would need to be rewelded
T3/4 Ebay turbo - $50
doesnt hold boost, ran low on oil. good for parts maybe
Rb25 S2 block - $150
98,000kms, stripped only to use head in my car
Rb25 turbo auto - $250
Rb25 inlet manifold base - $40
Rb25 inlet manifold top - $40
Rb20 polished rocker covers and valley cover - $100
just need a good clean
Rb25 standard turbo exhaust manifold - $50
Rb25 steam pipe top mount exhaust manifold - $400
Open to offers on all items.
Postage can be arranged at buyers expense though pickup is encouraged form Wagga Wagga NSW.
If youd like larger items to be sent im happy to drop them off to a courier to keep cost at a minimum.
Any inquiries leave inboxes or contact me on 0424599141. call or sms anytime
Rhys
If you require any other vl or r31 parts that arent listed than let me know
https://www.sau.com.au/forums/topic/398318-r31-vl-rb25-and-rb30-part-sellout/
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
