hey guys
tonight whilst driving my 32 i noticed that once it comes on boost it starts hesitating/ misfiring abit and a cloud of black smoke out the back. I put $20 of BP 98 in it before hand and thats when i started noticing it and thats the first time it happened, the night before i went on the Antilag cruise and again put fuel in before hand and it had no problems came on power fine and smooth.
the car has splitfire coil packs with standard BOSCH plugs, forward facing plenum with saard injectors and a 35R turbo with 44mm gate
im thinking it could be a bad batch of fuel?? possible coil pack?? and maybe the standard plugs have given up on life and thats causing the drama
it idles fine, drives fine with no misfire but as soon as it creeps up to about 4-4.5rpm as the power comes on thats when it starts to hesitate and misfire, sometimes its not bad then some other times its pretty bad any suggestions????
cheers
https://www.sau.com.au/forums/topic/398852-32-misfiring-hesitating/
Sounds like plugs or coils. When there is a lot of fuel/air going in it blows out the spark. Either gap is too large on the plugs or coils aren't making strong enough spark or spark is going somewhere else instead of to the plugs. If the gap is too large I.e. works ok with smaller gap plugs, then its likely the coils are getting old. Smaller gap is just a temp fix for the inevitable.
well i was gonna put new platinum plugs in and take it for a spin if no real change is there was gonna swap splitfires with my mrs's 32 and see if that makes a change then i can cross a few possible causes off my list
well i had a set of platinums sitting around so i put them in and drove it the hesitation is gone but still has abit of a misfire i looked inside each coil pack when i changed plugs and cylinder 1 coil had a white powdery resedue and the little coil spring inside is like gone and all other coils are clean and have no pwdery stuff in it, and the top of the old plug was powdery and all crapped up, so i have a feeling its a combination of shit plugs which are failing when hot? and a crapped out cylinder one coil pack?
ok so i swapped a whole coil pack assembly for all 6 cylinders and the harness from my mrs's car to mine and took it for a spin, still the same result, like a popping, misfiring sound, doesnt really seem to miss i think i can rule out its a coilpack if mine runs the same with 2 different harnesses, i even swapped the dud looking one with the white shit in it to her car and took hers for a drive and hers ran nicely no miss or hesitation, im going down the lines that the pooping/ miss sound is maybe from the screamer pipe under abit of heavy acceleration??, it doesnt do it all the time when on boost just sometimes through the rev range, might even pay to get plugs with a .8mm gap??
cant swap ignitor pack, i have a series 2 rb25 and the ignitor packs are built into the coil packs and ive swapped all of them and i still got the same result, maybe i need to get plugs with the right gap, whats weird is it ran fine before for ages then it started to play up, i swapped plugs with new platinums, it got alot better but not perfect
  • 5 weeks later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
