Hey guys,
Please, advise if I can use 255/35R18 tyres on 18x10 or 10.5 rims? How should they look on a GTR? A picture of this set-up will be greatly appreciated.
Cheers,
Lou
Just legal on 10in not on 10.5
Yeah 265 will go on a 10.5, even then they look a little "stretched"
255/35 will be quite stretched. Mexican is for GTS-t drivers, not GTR drivers!
If you want to fill the wheel you'll need 285s. I run AD08, 285s - rocking on a 10.5" rim. Looks PHAT.
255 on 10" will be ok
I run 265's. stretched..... :S
Did you need to roll the guards to fit them in? or is it all dandy?
I've only had half of the guard rolled (just the middle section). Didn't need to roll the entire guard to fit.
My car isn't super low however as i need suspension travel given the use it sees
I run a 255/35R18 Toyo Proxes R1R on a 10.5" rim on the back of my Cossie, has decent stretch and that tyre is quite wide for a 255.
Considering the car is a R33 GT-R that runs 245/45R17 originally I'd lean towards a naturally wide 265/35R18 (R1R, AD08 etc.) or a 275/35R18.
hey mate
if you wanna see what 265/35/18 looks on a 18x10 rim on a gtr have a look at my posts of my car when i got the new rota grids on it.
265 look a little stretched, i think for how low the car is i would not go a 285, however i might play around with how it sits!
R31nismoid's R33 Gtr with the 10.5 with the 285s looks pure porn, helps that it has everything, colour, stance, height, wheels. just buy his car lol. (seriously nice car man, loving the wheels!).
265 - little stretched, 285 - purposeful.
Not to mention from behind looks pure fat and wide ass.
    • Ironically the GTT was quite reliable in the 7 years of ownership. From memory I've only had to replace a radiator and coilpacks out of inconvenience
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
