Came of a R34 Gtt but will suit R33 Gtst's also as they are exactly the same.
For the people that don't know its the pipe that goes between the turbo and afm.
In good condition,
Also comes with the 2 clamps that hold on to the turbo and afm which isn't pictured.
asking $60 Pick up from Taylorslakes (Melb) or can post around Australia for an extra $10.
Call/ sms 0422756270 if interested.
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
