i will add i have opened up the box to have a look and inspect the crank, but that's it. I would have thought this would have been a normal procedure when buying an item, but it seems some members think that by me opening the box the crank could have been tampered with.
Just thought i'd let you know
Location to view or pickup?
Original long nose drive or converted with a collar?
Grub screwed or rock standard?
Edited by GTRPSI
part number is 12200-05u03 which is the part number for the r34 gtr crank
You are right but the only difference between the r33/34 gtr crank is the process used to balance them. As far as i am aware the 05u03 is the only one you can buy new from nissan anyway.
  • 1 month later...
