Hey everyone,
Have a heap of standard R32 GTR parts for sale...
Standard R32 Gtr turbos, both in great condition with no play, wheels in good condition only need a clean - $300
Standard turbo manifolds for rb26 - $100
Standard dumps rb26 - $50
Aircon setup for r32 gtr including compressor, radiator and hoses up to the firewall - $200
Standard Rb26 timing cover in blue - $50
standard R32 GTR camshafts with gears - $75
R32 GTR rear wing - $150
Standard RB26 intake manifold, no throttle bodies, does not leak and worked fine, just changed it for a plasmaman $100
Universal carbon wing at the moment the stands have spacers on each side to fit in the rear stock mount of the r32 gtr however front holes need to be drilled, had it on my r32 gtr before going a different direction is height adjustable i think 25cm and 40cm and is approx 155cm long, and about 26cm wide - $350 in great condition and has heavy duty feet for stands.
Standard r32 GTR brakes, front and rear, calipers are electric blue, rotors have a heap of meat left on them - $400
I can ship anything at the buyers expense, and open to offers on everything its all clogging up space and needs to go.
Contact me via PM or on 0434817247 and ill try to get back to you asap. All parts are located in Wollongong, about 1hr south of Sydney.
Na sorry mate, I'm not parting out the car, all these parts are lying around because the car has been modified somewhat significantly and they are all standard parts that I dont need...
Front Brakes sold!!!
Standard rear spoiler sold pending payment,
Bump on everything else make an offer!
Also have a full Hicas setup for r32 GTR including all lines that go to the front of the car $150
  • 3 weeks later...
Timing cover sold!
Long weekend bump!!!
Also have some 18x10 enzo D1R's in +18 offset, They have no rash or anything and are in excellent condition, wrapped in pirelli P Zero's front tyres are a bit worn on the inside rears are pretty much brand new, I think they have about 500kms on them. $1100 ono
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
