HKS GT2530 A/R.60 RB20/25 Bolt On Turbo.
- No lines.
- Bearings need to be replaced due to wear.
- Wastgate actuator included
$600
Location Melbourne Northern Suburbs.
Contact Sel 0432336944
post-48953-0-28012000-1336046436_thumb.jpgpost-48953-0-53580800-1336046459_thumb.jpgpost-48953-0-85623000-1336046478_thumb.jpgpost-48953-0-40466500-1336046502_thumb.jpg
Edited by selcuk
  • 2 months later...
Not going to cost as much as a full rebuild because i pulled it of as soon as it started to make the whining noise, most like bearings and seals, shaft shouldnt be worn out and both turbines are intact, $400 last price if you interested 0432336944 thanks.
Not going to cost as much as a full rebuild because i pulled it of as soon as it started to make the whining noise, most like bearings and seals, shaft shouldnt be worn out and both turbines are intact...
The HKS GT2530 uses a Garrett Core yes...
FYI:
Unfortunately, Garrett do not sell the bearings separately leaving your options to either purchasing a whole new center cartridge (basically everything aside from both housings), which is typically expensive...
Now, if just the seals need replacement, that’s not a problem. The inability to rebuild Garrett ball bearing turbochargers only applies when the bearings are damaged or out of tolerance.
MTQ, Precision etc will quote you on a new core everytime...
http://blog.theboostlab.com/?p=100
Garrett US have a core exchange program that can be an option for the buyer also.
  • 1 month later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
