[Vic] Stock R34 Gtt Rb25Det Bov & Crossover Pipe.will Suit The R33 Gtst Also. Can Post Oz Wide!
R34DE as in R34 with an RB25DE? So did you get this? Or you planning to? I'm not really sure what you're saying.
