does anyone know where you can pick up a cheap 'flat wing' for a 1994 r33 around the gold coast?
by flat wing i mean the ones that just come straight out off the boot, dont go up in the air. (as shown in photo)
I have found some on eBay but they are asking $220, is that a reasonable price for one?
https://www.sau.com.au/forums/topic/399574-r33-flat-spoiler/
