If there was any thought that alluded to the fact that I put this on through vanity or individuality, I think on reflection that there's a little bit of truth in that; the reason being that if this badge had persisted over the decades, I'd probably prefer the new one hehe...
The more I look at it though, the more aggressive the front looks - now that's a rationalisation :)
https://www.sau.com.au/forums/topic/399710-grille-badge/#findComment-6349843
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
