I've been looking for a new gear knob on ebay for my V35 350GT but i can't seem to find any that specifically say it will fit that car.
Just wondering if the 350z knobs would fit my car because i seem to be finding alot of those. 6 speed too.
Anyone that's purchased one for their 350gt let us know cheers
https://www.sau.com.au/forums/topic/399996-gear-knobs/
I've got the Tommy Kaira hebi bebi popular with the Z crowd. Shortens the shaft height because it mounts low on the stick if that's what you're after, probably not the choice for drifters tho :)
The low mounting height feels like it shortens the gate but due to it's 515 gram weight it maintains if not improves shifting effort.
https://www.sau.com.au/forums/topic/399996-gear-knobs/#findComment-6355045
  • 1 month later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
