it's a blow off valve... sits just before the throttle body on the R33 inlet pipe. It has some pipe that comes off the outlet and goes back in down near the air filter before the turbo, but after the air flow meter. It also has a small hose that goes to the inlet plenum that opens the valve when you take your foot off the accellerator
  • Replies 41
BOV = Blow off Valve; Basically it either releases (atmo) or re-directs (plumb-back) the pressurised air from the inlet pipes when off throttle....
in more detail:
atmo; sends the pressurised air out of the intake pipes to the atmosphere (goes wooosh... lol)
plum-back; puts the air back through the turbo.....
i thinks that's about right.... if any one wants to elaborate you're more than welcome....
OK...I said it was a stupid question!!! So i take it that the fluttering sound is bad and that i should look into fixing it.....however my blowoff valve sound like it is working OK. Also sometimes when i apply full load to the engine, my car kinda stutters and jutters and then fangs....
sounds like pinging.... dyno's are great to test all that.... most likely something simple....
as for the BOV, you can tighten them to only go off above certain pressures/revs...I've done that with mine, which makes it flutter under about 3500 RPM then go whooosh above....
R33_BO:
It sounds like you have a BOV that vents into the atmosphere. This means that when you change gears and alike your BOV realises air outside the air intake, which means that your engine thinks you have more air in the air intake then there actully is. It does this through your AFM (Air Fuel Meter, the thing Connected to your air Filter - black box thing). Not all cars have these so they can run atmospheric BOV's but unfortunatly Skylines do...
You should look into getting a stock BOV on your car and all should be fine if the BOV is your problem...
It could be other things, dirty AFM etc...
my car makes the fluttering sound just recently... it just happened after i upgraded my air filter form the standard box.. beofre i did change the air filter to a trust (airinx), it was just making thew woooshhh sound... now with the filter on, it goes tshh tshh tshh tshh... is that a bad thing?
Guest INASNT
the flutter is ok, but if u want to be fully sick and have the dut dut dut dut sound then get a nice big turbo like a 3040 run it at around 1 bar with no bov at all and u will be fully sick. I did this with mine for about 2 weeks till i found my gtr bov's. It sounds good but farks the turbo bearings and tip of the comp wheel if u run like that for a long time.
Just like everything else u will get bored of the fully sick sound after awhile
the sound youre hearing is not caused by the pod filter, but you can hear when you fitted the pod because standard box filters the noise. The flutter noise is caused by either you've blocked your bov, or you have an aftermarket bov setup with a hard spring, causing compressor surge.
How does it go again?
the sound goes woosh shh shh shh shh... Never stalled on me, and no idle problems or nothing.. People say on the nissan silvia forums that the flutter sound is becuase when u take ur foot off the accelarator the turbine wheel spins backwards thus cutting back through the air making the flutter sound, or something like that iforgot exactly.. im so confused now lol..
mate the wheel will not spin backwards. It may slow down do to the pressure applied but turbo rewind is a myth. Think about it ur turbine is spinning over 10,000rpm for max .5 seconds when u change gears it won't cause the wheel to slow down to a halt then start spinning backwards in that amount of time. There was a really good article on autospeed about it was ages ago tho.
that's why the skyline forums is better than the silvia forums... cos at least here we know what we are talking about!!! :P
What happens is the pressure wave reflects off the closed throttle and back towards the turbo. When it reaches the turbo, the spinning wheel chops the pressure wave (also referred to as compressed air). That is the sound you hear. It could also be you BOV opening and closing (like mine does)... unless you have removed it
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
