Hey mate, would you have been in Fairfield area today? I saw a silver 33 with wheels like yours going around my road.
Today I saw the car u were talking about. I was travelling around Parramatta BP on the opposite direction and i saw him. I wanted to say hi but the light was green. Looks like a twin brother of my car. LOL Hope to find out how drives it.
Lol. On my fulls now so looking at getting a turbocharged car. Maybe an evo? :ninja:
definitely an evo lol
Sinno, hows things man. Haha I thought u were into Skylines. At least get a manual turbocharged r34 4 door sedan. :w00t:
First of my noob questions which I don't think is new thread worthy, so I'll post it here.
I've got a few buttons in my car that I'm not sure what it does.
First one is the steering wheel button with On/Off (image attached). What does this do? I tried pressing it and stuff but don't seem to notice any difference.
Second, what is A/T Snow? The guy who I got the car from told me it did something to speed/handling but not too sure what it actually does.
Third, theres a cigarete looking button with up and down arrows, which I have no idea about at all.
Please tell me what they are and do.
haha I want to say hi as well. They were ripping up and down my road on Sunday when I was washing my car. Seen another silver 34 with a Altia kit on the same day. Would like to meet fellow skylines around my area!
Where do u live. Maybe we can meet at Parramatta today. PM me your contact no. :cheers:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
