Hey i have 2x HKS 25/35 turbo's for sale, these are an awesome turbo to suit both RB20's and RB25's to make around 250-260rwkw, also have a HKS 25/40 for up near the 300rwkw mark, they are all direct bolt ons, with awesome response, maintaining the low mount position, great for cops!!
Asking $1100 for the 25/35 and $1200 for the 25/40, including all the lines and elbow to make it fit on directly to RB's.
Also have a T04E with a .50 comp, .82 turbine, high mount turbo with t3 flange - $800
all are in great nick with minimal play!
Located near mitcham in SA, can post anywhere in Aus.
any idea what sort of full boost figures for rb20 (for the 25/35, i presume it's the smallest?)
would the response be on par with the stock rb25 turbo on the rb20? (full boost around 4k)
hey mate, i got this with my rb20 which just runs stock everything except fuel mods etc. really depends what boost your running, but i was getting 18psi by 4500. this 20 was limited to 7000rpm for some reason though, you can run them to 7500-8000, so a pretty healthy power band of around 3500 at full boost/torque.
  • 1 month later...
    • I purchased some (used but new to me) Yokohama A050 Mediums to try out for the first time and fitted them up to one of my sets of Rays TE Fortesst's. Sizes are 235/45R17 front and 255/40R17 rear. They are very chonky compared to the same sized AD09 on the same sized rim. Some fiddling will be needed to make them fit. How much camber do these like as a general rule? I imagine more than the rear camber of -1.5' I typically run. So my plan is to target -3.8 front and -2 rear
    • If you want to test it under temperature, I think you should enter the One Raceway day tomorrow with Duncan!
    • That looks great Mark!
    • Yeah yeah, the oven did get a good clean after the "baking"...LOL In other, wrinkle black painted stuff news, expansion tank and PS reservoir all fitted up and tested at temp Much nicer than the yellow stained plastics
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
