Update from Import Monster:
Nissan only had 2 full sets and the two right hand side ones in stock, they are going to make new ones and their eta to our shop in Japan is early August, meaning arrival to Melb in mid September.
I enquired about the eta on the 2 existing sets and the 2 right hand side ones and this was the reply:
we will ship them out as the arrive to us, so the ones in stock now will probably go in the container leaving Japan this week and arrive here in around 5 weeks
I feel the fairest way of allocating the first 2 pairs is in order of confirmed interest, so this means myself and then beans.
Edited by Marshstag
  • Replies 59
and the rh ones? Andrew seeing as we are both in Adelaide, we should combine the postage to here and then we can catch up to collect?
Yes, the right hand ones will be coming at the same time.
Agreed that we should go in on postage together!
  • 4 weeks later...
Hi all,
The latest update is still as above, i.e. that Nissan were making new weather shields to complete the order. I will contact Import Monster to find out where everything is at.
You're all also welcome to contact Import Monster directly (PM or [email protected]). If you identify that you're part of this group buy, I am sure that Aaron will be more than happy to help.
Hi all,
Thanks mate!
This was the latest update from Import Monster as of last Thursday:
we have 3 full sets and the single coming in about a week, the rest arrived to the shop in Japan about a week ago and are going into a container we're packing next week
So what that means is the first shipment will be allocated in the order of earliest confirmed GB participants.
The 3 pairs:
Marshstag
beans
Global_Warmer
The 1 RHS single
Zorro
hey andrew how's going dude? just letting u know that i am overseas at moment bt i will be back in sept 19th . wondering if thats ok ,it was delivered to your house and i can pick up from u .?
That will be fine Fabien
  • 3 weeks later...
So, are they here yet?
Yep your RHS single is in Melbourne at the moment, along with the 3 pairs for me, beans and Global_Warmer. I'm in contact with Import Monster to get the Adelaide ones couriered to me. Once I have some more details from him I'll PM you and beans.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
