Hey Everyone, I'm new to the site.
I've been in love with Skylines since I was around 13 years old, specifically R32's.
I owned a R32 GTS-T about 6 years ago and just two weeks ago I finally became the owner of a fairly clean R32 GTR.
I'm up in Cairns and haven't seen too many GTR's getting around so if anyone is in the area and keen to catch up hit me up.
Cheers,
Ash
https://www.sau.com.au/forums/topic/400895-qld-newbie/
