git Bride Brix recliner in red, on R32/R33/A31 Rail, great condition, no rips/tears/excessive wear, just has a small stain on the back of the headrest as pictured below.
$750 with the rail and 1.5x1.5 red bride material.
0422 318 946
cheers for looking.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
