Wiring Headache Need A Recommended Workshop To Take This On...
Okay soo heres the deal
I got an r34 gt four 2 door awd
I swapped the rb25de to an rb25det neo
Z32 meter
34 gtr manifolds and turbos and front pipe
33 gtr dumps
Stagea S2 tiptrpnic box
Stagea s2 ecu
Stagea s2 wiring loom
Im uaing the loom due to the fact it has the plugs for tiptronic box and the ecu has the auto trans computer built in.
Now heres my dillema since the wiring loom is obviously different to the plugs inside the car theres 2 intotal that dont match up the stagea loom
The car can turn over but whont start due to missing 12 volts to the fuel pump most things work ive had a go at the wiring but ove finnaly faced the fact is beyond my own area of knowledge
Can anyone recomend a workahop who will take this on? None of the auto elecs from where i am moe victoria... Sigh yeah yeah yeah pay it out more and ask me if i wear moccasins .. :) anyway they dont want a bar of it down here and please be helpfull and dont give me the usual line of "why didnt you go rb26 or why didnt you go manual" heard it soo often i juat wanted to make something unique and to distract me away from my battlefield and diablo urges
Anyway any help would be sweet :)
prob easiest way would be to hard wire the pump off the battery to confirm all is OK
then someone can focus on restoring the fuel pump power relay from the main ecu
cant be that hard
any decent jap workshop could do it
chasers / racepace / re customs / dr drift
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
