Hi all,
I'm having problem with uneven tire wear due to the alignment geometry on the Vs, as I don't really drive that much It wasn't that much of an issue for me, but I'm planning to lower the car in the near future so I'm on the market for some SPC camber kits. I was wondering if anyone would be interested in a group buy for these kits to save some dollars :thumbsup:
Now many of you would have heard about SPC, for those of you who don't, there are plenty of threads and discussions on SPC camber kits on g35driver.com, most people who run these kits in their cars has no issues and were generally happy with it and will recommend them to others. If your tires are wearing out prematurely like mine then I'd strongly suggest you invest in these as the price of replacing 2 tires is pretty much the same as buying these kits, well for me at least if you're running 19's or bigger :whistling:
I'm already in contact with a vendor for SPC and he has given me some initial quotes but says he might have a little more room to work with the price if I can manage to get enough interest, so far the quote i got are:
Retail prices
SPC Front Control Arm L&R Pair RRP: $385Usd
http://thmotorsports...5/i-397516.aspx
SPC Rear Camber/Toe Kit RRP: $89.50Usd ($179 for a pair)
http://thmotorsports...0/i-396571.aspx
These prices don't include shipping, you're looking at around $60 (rear) and $100 (front) for shipping
Quoted prices
Front control arm pair $475 shipped
Rear camber/toe kit pair $220 shipped
Any questions feel free to ask, for those of you who have these kits it'd be greatly appreciated if you could give some feedback on them with regards to performance,installation, fitment or anything you like to add in.
Cheers
https://www.sau.com.au/forums/topic/401036-eoi-spc-camber-kits-group-buy/
I'm interested, also looking at the SPL fronts
Has anyone done a comparison based on adjustable camber range?
I'm not sure about the SPL's but the SPC are adjustable up to 6 degrees front and rear adjustments are +/-4.00 degree Toe +/-3.00 degree
I'd be interested in the rear camber kit.
Hopefully they can squeeze a bit on the price, as it works out to be $40.00 postage based on the retail price on the site, which is OK but not amazing.
If we can get 5+ confirmed orders it'd be $200 shipped, $20 for shipping is a steal i reckon
how many people do we need to get these prices down? I'm interested in the fronts for sedan.
According to the seller, we need 5 confirmed orders. Right now we have 4 people who are interested in the rear and 2 for the front (You and I)
If its the same parts as a 350Z I'd be interested.
Yes its the same for the Z
^ So you are in? :rolleyes:, I'm making a list of confirmed buyers as we progress. hopefully more people will be interested.
Confirmed List
Front Kit
  1. kvnz88
Rear Kit
  1. kvnz88
  2. falconcoupe
Copy and add your name to the list for those who are interested. cheers
After looking at the options and details, I'm in for both front and rear, assuming they are cheaper than ordering separately.
Confirmed List
Front Kit
  • kvnz88
  • Dreadnought
Rear Kit
  • kvnz88
  • falconcoupe
  • Dreadnought
5 people across both parts? Or 5 each part? And what sort of price drop?
It's 5 parts each.
$200 rear for 5+ orders, $220 otherwise
if we can get 5 + orders for the front i'll work something out with the seller, hopefully can get it down to 450 or less..i'll keep you guys updated
Edited by kvnz88
I am keen for a rear kit. Not overly sure if I need the front?
I will be lowering the car with some 350Z springs. Front guards have already been rolled. And my wheel set up is as follows
Front - 19x9.5 +12 with 245s
Rear - 19x10.5 +12 with 265s
Would I need the front kit? Thoughts?
Confirmed List
Front Kit
  • kvnz88
  • Dreadnought
Rear Kit
  • kvnz88
  • falconcoupe
  • Dreadnought
  • Mayo_85
you probably won't need the fronts with an 1" drop, however the rear ones are always recommended with even a slight drop. Heck i even wanted to get the rears without any drop. you can always decide later when you get them aligned after you've installed the springs and see if it can be adjusted to near oem specs.
anyway guys i think we should set a deadline for this in order for me to start ordering, i say give it one more week, Tuesday 19th of June. hopefully 1 or more people can jump in to save the day, or else ( for those of you who are interested, are ok with $220) i'll put the order through. I'm holding off the fronts for now as there are just not enough interest.
Might be a silly question, but can the rears be used for camber or toe, like an universal arm or are they all different parts? The way the site is set out, implies its an universal arm with all the description under one heading.
I really want the SPL Pro products, but I need to separate what I want from what I need, spending too much already... :(
Edited by 81gSKy
I may be keen on the rears, how much - adjustment can they do... my current are maxed out at 5.5deg.
I think they only run 5 Degrees, which are you running now?
SPL group buy? I need fronts to fit the new square 11s, haven't seen the rears, but if they have similar adjustment ranges to SPC then I'm sold....
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
