hey
i'm Ryan (aka rhino - and in no way am I built like that lol - but I like my cars to be) - and i'm in adelaide north east area.
ive got an R32 which im thinking about getting onto the track - just need $$$$ and the knowledge, which I hope to learn about from here!
if its not cars, im into music, cycling and general fitness
looking forward to seeing u in my threads :P
later!
rhino
https://www.sau.com.au/forums/topic/401373-hey/
Welcome to the forum Rhino!!
Just dont start too many threads without using the search feature first or you will get flamed...
Most people on here are here for the same reason and interests and can be a friendly bunch BUT you can get the odd person that will have a crack at you over new threads... But you should enjoy!! ;)
https://www.sau.com.au/forums/topic/401373-hey/#findComment-6377168
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
