Alright so as some of you guys may or may not know, Perth Underground Magazine is hosting there 1st Issue Launch at the Claremont Showgrounds on the 17th June, big Show n shine, promo girls, the lot, Link Below,
https://www.facebook.com/events/316630158413822/
If you havent got facebook Im sorry I cudnt find it elsewhere, but the basics details are above,
Im representing Savage Motorsport in the Show n Shine event and I thoufh it wud be a good opportunity to gather up as many West aussie V35s to show some support and meet n greet each other on the day, tell me what u think and if weve got a few we can organise a time n place,
Dont forget to come see me if ya see my V on show, im keen to meet anyone :D
Cheers,
Brenton
https://www.sau.com.au/forums/topic/401407-perth-v35s-meet/
Hey guys, seems like theres a few keen people here, wouldnt mind starting a little group, start off with a facebook group or something like that, I know a couple of our V35's are a little older (no offense intended at all :P ) not 100% sure if ur all up with facebook and that side of the social networking, thats a shame to hear Paul & Kohby, but yeah come on Troy and Holly, itll be well worth it I hope, put some names to faces get a regular group together sounds cool,
Hope to see you all there - Ive gotta get there early 8am and help setup the clubs tents and crap :/ haha, lets get the V35's back into the Perth community. I know your out thereeeeee, :yes:
cheers,
Brenton
https://www.sau.com.au/forums/topic/401407-perth-v35s-meet/#findComment-6400048
Yea no worries man, the launch opens at 10:30, no rush guys its on all day :)
Gate 1, Corner of Shenton and Graylands Road
Theres free parking in the showgrounds and its just $10 entry guys no excuses haha, see if you can all park together in the showgrounds :D I dont want to have to walk 10Km around to each car and it would look good XD
https://www.sau.com.au/forums/topic/401407-perth-v35s-meet/#findComment-6402171
I'm going to try to make it tomorrow, Its my dads birthday and we have breakfast and lunch plans, so I'm hoping to get to the showgrounds in the afternoon.
Facebook social group is a great idea! And hopefully we can get a near future official V35 meet & greet organized:)
Edited by Holly
https://www.sau.com.au/forums/topic/401407-perth-v35s-meet/#findComment-6402291
Hey Guys, quick update, anyone whos keen on a facebook group and a cruise/meet sometime, add me on facebook;
https://www.facebook.com/profile.php?id=659342844
and send me a message letting me know who you are XD, to create a group you have to list people to add before it can be made, so lets get as many as possible and get a cruise goin, let Perth know we're still out here :DD
https://www.sau.com.au/forums/topic/401407-perth-v35s-meet/#findComment-6403987
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
