  • 1 month later...
  • 3 weeks later...
Are you interested in building your own? I have a ca18de if you want it, was running perfectly when removed. 6 pack of Jim cans and take it away, be happy to have it out of the shed. Located north of Brisbane. Cheers, Matt 0418719626
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
