Parts as listed below.
Pick up preffered (Can post at cost if required.)
PM for Pics and other enquiries.
No chit chat...
Wanna chat go to wasteland.
Wanna haggle use PM.
01•R32 RB20 Turbo (Minimum Play, No Smoke/Leaks, Good Nick)__________160Buxx
02•R32 Custom Alloy Catch Can Setup__________150Buxx
03•Custom R32 Intercooler Piping (Crossover pipe deleted and a HKS SSQV Mounted near throttlebody)__________180Buxx
04•Cooling Pro Intercooler Core 600x300x76 __________100Buxx
**03 & 04__________250Buxx**
05•Apexi 60mm Boost Guage with Stand__________100Buxx
06•Greddy Profec B Spec II__________300Buxx
07•Surge Tank Setup with 044__________320Buxx
08•Bosch 044 (Used)__________150Buxx
09•R34 GTR Injectors clean & tested then used for ~1500kms__________280Buxx **Can chuck in R34 GTR Rail & FPR for 50Buxx**
10•R33 GTR (V-Spec) Drivers Seat__________450Buxx
11•R32 GTSt (Late Model) Passenger Seat__________50Buxx
12•R32 GTSt (Late Model) Rear Seat__________100Buxx
13•R32 GTSt Front Bar in Blue (Cut for FMIC)__________120Buxx
14•R32 GTSt Reo (Cut for FMIC)__________120Buxx
15•R32 Front Lights (Fisheye) & indicators__________120Buxx
(has eyelids glued on)
16•Alternator (RB20)__________80Buxx
17•Starter (RB20)__________80Buxx
18•Wheels 4x 5spoke 17x8 unsure of offset.
(Good for skids or trailer) plenty of tread left.__________250Buxx
19•Alloy Radiator 42mm__________120Buxx
20•R32 (All) Cusco F&R Strut Braces__________270Buxx Pair or 150Buxx ea (rear wont be sold until front is sold)
21•RB20DET 4WD Complete (Has Knock)__________200Buxx
22•Haltech E6K Standalone ECU with Full wiring looms & wiring diagrams, relays, switches, coils, coil leads, intake temp sensor, coolant temp sensor & 3bar map sensors, pulled from my R32 GTS4 in perfect nick but can be wired into anycar__________900Buxx
**More info can be found on this pdf...**
http://www.fueltech.com.au/pdfs/HalE6K.pdf
***Manual can be found here:
http://www.haltech.com/wp-content/uploads/2011/01/E6KManual.pdf***
23•HKS GT28 Cast Dumps Suit RB26 with GT28 Turbos (Bell mouth style, Hi Flow, Can be machined out.) Paid 550+Post, Sell for__________500Buxx Posted
24•Kakimoto Regu-06&R 3" Catback Exhuast Suit R32 GTSt, GTS4 & GTR (Mid Muffler replaced with Hotdog)__________380Buxx
25•R33 Radiator Perfect Nick__________75Buxx
26•HKS GTRS Turbos Suit RB26/27/28/30/31 etc etc Perfect__________2700Buxx
27•RPM Custom Oil Cooler & Remote Filter Setup R32 GTR (Passenger Side Mounted)__________550Buxx
28•RPM Custom Catch Can Setup__________200Buxx
29•RB25DET Long Motor No Accessories (From R34 Non Neo) ~168psi accross all cylinders__________1400Buxx
more to come
Edited by krayzie32
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
