Still interested in trades for Mint R32 & R33 GTRs with cash on top. Some other cars of interest are E36 M3s and open to a few other options, but has to be similar to the car mentioned.
$11K with RWC absolute lowest I will let this clean WRX go!
That totally depends on what car you have and how much I am willing to put on top. For an extra $6-$8K on top of my sale price of $11K, I can get into a MINT R32 or R33 GTR, MINT E36 M3 or MINT EVO7. So what do you have? Mods etc give me as much info as possible and I will let you know how much I can put on top.
Thx
PM details as all I said was for an extra $8K this is what I can currently get. I have more than that if the car is RIGHT.
PM me details and will go from there.
The problem is that I will struggle to sell your car for $11,000, there are hundreds on car sales for less than $10,000
Like this one for $8,500
http://www.carsales.com.au/private/details/subaru-impreza-2000-13099013?base=1216&vertical=Car&cr=37&page=4&eapi=2&__N=1246+1247+1252+1282+1216&num=15&silo=Stock&items=[Make:SUBARU,Model:IMPREZA,BaseEnabledBadge:WRX%20AWD]&sort=~Price
So while you may be able to get a mint 33 for $19,000, yours may only be worth $8,000
If you undervalue the car your buying, same happens to the car your selling
Thats why I asked how much cash you had, I would want $11,000 minimum for my car on top, as I would only on sell your Rex,and I doubt you would pay that.
You cant buy cheap and sell dear
Well your GTR, if that's what you have must be damn good if your worried about me selling dear! I know in this market, my WRX will get $11K. The car in the link has nearly 190,000kms on it and mine has 130,000kms with some great service receipts.
I feel I have dropped my car at market value for what it is, started out selling it for $13K but knew that was not realistic. I know exactly what you are saying, but you still havent given me any info on your car? I have more than $11K if I feel the car is worthy, so please show me what you have!!
Still haven't received info re your car? Not another shit talker on a car forum are you?
Who would have thought they still exist??
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
