Hi,
As per title.
I bought these a couple of months ago for a smaller sized wheel with tyres for track.
Changed my mind and will look at something else now, a 17x10.5 perhaps with +0 offset.
To the point.
Discontinued LMGT4
Bronze Rays Nismo 17x9 +22.
These are super light, forged monoblocks.
They're in original paint, that special, oh so special Anodized Bronze.
Unfortunately 2 rims have gutter rash, the other two have slight marks.
Over all not too bad for the age of the wheel (see size and info sticker).
The nismo stickers are still there, slowly missing edges.
Tyres are Bridgestone Potenza GIII - 245/45/17. Thread depth shown in photos.
Two of the tyres have a bit of camber wear, but the rest of the tyre is fine with plenty of thread.
One tyre has some flaky substance on it, not sure what it is, thought i'd post that too.
Pictures will describe everything better than I can, so see below.
Price. $2500 including everything you see in pictures.
I believe I have centre caps with the Rays logo on it, $100 for those (from my old set) if you want them.
I can wrap and post anywhere, will put a piece of cardboard on each side and wrap with rubbish bags :) Easy and cheap.
Would fit a GTS-T, GTT, S15, R32 GTR, most things quite easily, depends on how stanced you want it.
Pictures:
BUMP!
I'm going to Sydney for the Low Down meet next weekend and will happily bring these down with me --> free postage :)
--> Only for a deposit first.
Thanks
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
