The new collar will be 40.7mm so you have probably just bought a collar for nothing. Don't waste any more money by getting it fitted. Yes it would entail machining off the old collar and replacing it with one exactly the same. Its only worth doing if you have the older style shorter collar that only partly engages with the pump.
Great can anyone confirm this as i just lost 198 bux on a collar
No one's going to pay you $195 for a crank collar - your best bet is to see if your supplier will take it back less a handling fee maybe for a credit if not a refund so that you can buy something else off them.
The factory crank collars tend to be far too small. Too much clearance between it and the pump gear.
Sounds like your engine is built so your stuck with the factory drive. At least its a long nose one though.
Balanced crank is good as is the ATI balancer.
More oil pressure is better to a point. AS A MINIMUM you want 10PSI per 1,000RPM. Oil pressure also depends a lot on what viscosity oil your using.
But lets say its a street car, you have your rev limiter set to 7,500 RPM, when the oil is hot, you would like around 90PSI at around 4,000RPM all the way through to 7,500RPM. Being an RB26 your rev limiter may be higher.
The more oil pressure you have the better (higher pressure around the bearings prolongs bearing life), but the more oil pressure you have the more problems you have trying to get the oil back down to the sump as quick as possible.
Why is this said if r33 crank is ok?
Everyone agrees that the early short crank collars should be replaced to safeguard the oil pump but there is a theory that the later full length collars and therefore the Jun and Tomei collars (and the ones that I sell) allow too much clearance and therefore destroy oil pumps. I don't accept that this theory is by any means proven but those that believe it either weld up their cranks and machine them down to allow less clearance or else get bigger (than 40.7mm) collars made up. I don't know how they pan out.
There are hundreds or probably thousands of RB engines with stock full length collars that have not destroyed their oil pumps so I remain unconvinced.
In any case the collar you have bought will just replicate the collar you already have so that is why it is not worth fitting.
because there may be too much clearance and not enough meat on the std crank. the oil drive on the std crank is only cast and with a hard steel oil pump it may wear. installing a hard steel crank collar should lessen this and u should have a better clearance. just wait till u get the collar mate dont stress.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
