Yeh the original oil filter screws onto that adaptor then the hoses go to the cooler
Yeh there are different kits where the oil filter is relocated...
cheers
cheers
Next question. Does this add to your oil reservoir? Does the cooler have to be mounted low so it stays full when the engine's not running? Otherwise I can imagine that it will drain and give a high reading on the dipstick. Therefore when you fill it to the high mark for the first time and start the car, the sump level will get even lower as it has to fill the lines and cooler before reaching the engine.
Did that make sense? Basically, how do you get your oil levels right?
Thanks Tony,
Adrian
hey adrian...You might want to post up a thread inthe general section i honestly dont know how you get the levels right but i just put the required amount even with an oil cooler...
post up a thread could be interesting
  • 1 month later...
Nah thats all the lines it needs...As for fitting a bracket needs to be made up as the last one was lost when taken off the car...
Oil cooler is best behind the Radiator
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
