selling my current drive line.
r34 rb25de neo with engine harness modified by Quikfit motorsport to suit r32. plugs straight in. engine has around 80,000 km. removed from r34 at about 60,000km. oil changed about every 3,500km with the best oil that i could pinch from work and always looked after. always used 98 octane or 95 when not available. is a 4wd engine. currently has a modified r33 gtr sump for 2wd application but i also have a r32 gtr 4wd sump here.
engine currently has a sc14 supercharger fitted and has been on the dyno to check for correct mixtures. all good. only 4psi activated by switch. hardly ever used it. easilly removed and intake pipe fabricated to an airbox.
would be an excellent power upgrade for a p plater.
has an rb20 5 speed box with excedy hd clutch attached. oil changed yearly.
will be selling everything in the engine bay and stuff that relates to driveline like manual pedals, clutch lines, master and slave, radiator, harnesses,etc.
extremely reliable. very torquey engine. any tests welcome. is currently running in my r32. test drives welcome.
looking for around $1750 ono the lot. will seperate and remove once engine is sold.
contact me by sms or call with any questions as i dont get on here very often. 0401631925.
located east maitland. near newcastle.
may swap or part payment for items of interest. gtr or performance parts?
Edited by Chad__
$900 for engine ecu and harness? thats less than what i payed for the harness and for it to be modified. i just really want to start work on my car asap but i kno i wont be able to sell it without the buyer seeing it running in the car.
  • 6 months later...
  • 4 months later...
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
