Hey all.....
Thinking of selling up my collection of VSKF wheels to raise dollars for Japan....
I was going to make up a full set of boss size vskf and run them on the 32, but figured once I modify the car to fit them, EVERYTHING else will look sunken and shit...
And I need to raise dollars for Japan trip!
7 Wheels in total!
All 18 inch.
Various sizes and a combination of Burning Black and Chrome.
Includes an ADDITIONAL set of Inner and Outer Lips to make 11 and 12 inch wide rims!
Will post more pictures and better descriptions tomorrow!!
Below is a pic of a mocked up 12" wide rim.
Sell the lot for $3000
When people are selling a pair for $1400..... 7 Wheels for $3k aint bad!
Hokay!
So here are the wheels that I have!
2x 18x8.5 +32 (Burning Black)
2x 18x8.5 +38 (Burning Black, 1 wheel with bent lip, Repairable.)
2x 18x8 +33 (Chrome, 1 had severely bent lip so I was going to these centres are for the 12" barrels)
1x 18x9.5 +39 (Burning Black)
2x Barrels 12" Wide
2x Barrels 11' Wide
The lot for $3000 firm.....
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
