Odyssey batteries seem to be good, but they are pretty expensive :) Their CCA rating is pretty high too. A mate runs them on his Evo race car that is still road driven occasionally but it sits for long periods and still starts :)
yea i use a trickle charger on mine. good for the battery, and my alarm drains my battery pretty quick.. only probably drive mine once a fortnight or something...
i bought a new battery when i got it about 6 months ago, but i can remeber what i got, i just took it out and went to super cheap and got one that was of at least the same rating or better, and the same size of course...
I wouldn't go near an Odyssey again if someone gave it to me for free. Had bad experiences with 2 of them now, where a regular type of $80 battery works fine.
Oh really? Well it's good to hear both sides!!! I considered it but the price was a bit rich...
What about those Optima's? Any better?
If Ash says a normal battery is fine, then I guess I'll grab a normal battery haha! I thought it's best to get something with a higher CCA rating (maybe 500+) but then again, I know nothing about car batteries.
I might just do what GTR-34A said and pull it out and take it to a shop.
yea mate mines been working fine for 6 months so far, it died once when i first got it and didnt have the trickle charger, since i have gotten the trickle charger i have had no problem... it died from my alarm draining it though.. it cost me around $150 from memory and had a CCA rating of 550 or 600+ maybe..
I am surprised you didnt get an Optima or something because they are Yellow Anthony :ph34r:
Yeah higher CCA is good, i got the highest that i could for my car in the size of the factory one but i doubt it will be enough in the long run.......
ha i think i actually got century battery which is yellow!
I'll most likely get a similar battery. Did you also get the trickle charger from SuperCheap?
yea mate, trickle charger was about $60 maybe?.. not too much, just plug into the wall and attach at the front etc... works well.
You can get a normal one with a decent CCA. They might not last as long as an Optima say (if they are not issue filled like my 2x Od were)... But when they are less than half the price type of thing... I'm sure you see where I'm going. :)
Don't get me wrong, the higher end batteries can be good/decent and they do pack more punch in a smaller housing type thing... But you can get quite a sizable battery in the back. I'll be visiting mine tomorrow so i'll try get a photo to show ya.
That and I had an expensive dry cell last two years of maybe 2-3 full discharges. I raged VERY hard. Of course the warranty had just elapsed.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
