lol martin funny shit, i need a weeks notice so i dont organise to do something else haha
He has given you 5 weeks notice :P I think thats enough Mr Popular :laugh:
I didn't see it but someone just said it was racing or something.... If it was, well.... :no:
Either way, it's going to be very bad press even if it's an innocent mistake, but to be honest it's hard to flip a car while behaving.... ACA and TT are gunna have new footage and have a field day....
Let's keep our Newy scene clean :) no idiots... We all know who I mean....
didnt hear where it was, but from his family on the news id say west sydney.
to flip he must have hit the gutter side on, i mean you saw me at at texi haha.3rd gear, turn the wheel, rip the hand brake haha.
could of been chris, only saw a glimpse of it, i didnt see the cut outs in the side of it for the standard 34 front bar
