I started a long reply.... Then thought "why bother".... Benji, your killing me man.... Your probation is ok cus your not trolling BUT you are posting epic novels which are epic fail, and posting in ANY thread with the same stuff....
My advice, start a build thread.... Contain all your mods and plans in there (like others have suggested), keep the posts basic and read and learn, keep enjoying SAU... Oh and stop hitting on 14yo at Supre :laugh:
Yeah dude, I always end up rambling when I am on uni holidays. Will be sure to start a build thread once my first batch of parts come from Japan (^_-)-☆
Also have a set of Kumho Ecsta XS (KU36) tires and a 1.0kg dry powder extinguisher waiting to be fitted. Stripped out the carpet in the rear of the S15 in order to counteract the 1.0kg weight gain of the fire extinguisher which will be mounted near the centre console (^^♪
I didn't manage to get the two pieces of carpet from the rear quarter panels as there was a big clip on each one which I couldn't manage to get off. Also took out the spare tire.
Your a dumb ass :P don't take the carpet out of a street car ya clown!! If you want weight reduction you'd have to go drastic, BUT it's a fkn street car.... Carpet and seats make it quiet!!
lose 1 kg of weight if your that concerned, or get a skyline for the extra torque haha
Skylines are cool but cost wayyy too much to maintain for me to be able to afford. Whilst they have more torque, also less fuel efficient!!
The carpet was taken out of the boot in the rear so pretty stealthy and completely legal modification! Was tempted to take out the rear seat though but once I saw 2 bolts clamping the rear seat that idea quickly went out the window (^^♪
Thinking I'm happy with the weight reduction. Anyway, just realised I'm rambling again. Back on topic =)!
whats to maintain? i do the oil every 5000kms thats it. same as yours.
and i doubt an s15 would be much better then a gtt, gtts are pretty good on fuel.
haha rear seats weigh like 1kg as well, you will not notice this. are you gunna take a shit every time you wanna drive fast? this is the difference your making.
^^^ this....
Oh, and not all GTT's are good on fuel :P
Literally lol'ed IRL at the taking a poo before driving part.
The S15 got around 7.5L/100kms when my dad drove it home from Sydney rather tentatively. The SR20DET combined with the S chassis is the ultimate combination for performance on a budget (^_-)-☆ .
The Toyota Supra would be the ultimate 6 cylinder performance car/budget supercar due to the rear wheel drive powertrain and 3.0 litre race inspired 2JZ which is basically a torque monster.....R32/33/34 GTR are also on par in performance I'd say, albeit way more expensive to maintain due to the higher revving engine (RB26) and all wheel drive powertrain.
really?? thats pretty good actually, thats like what my 1.8L tiida gets and way better then my camry :S
you sure about those figures??
Just checked carsguides to make sure I hadn't calculated it wrong...turns out what I said was about right
http://www.carsguide.com.au/search/specs-search/?&Ns=pRSS_SortDate%7C1&N=4294967154+4294962594++490+4294965960
Anyway, I think if you were to get stuck into it and come on boost frequently then fuel consumption would go wayyyy up.
yeah fair enough, id probs get better economy if i had the 5-7 boost instead of 10psi all the time too haha.
must run like an NA if your gentle, i think the best ive got is 650? maybe 700. and i think its a 65L tank
Commodore drivers :no:
So has Benji gone into hiding yet?
Been a productive day today as I couldn't get the old tiles off the wall in the kitchen without destroying the wall in the process
Decided to cut the gyprock and tiles out completely and put some new sheets up.
Just finished setting it and can sand and undercoat tomorrow
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
    • Temp = -21.052 X Voltage + 114   That should get you pretty close. Calcs based on two points I could do easy calcs on (30 and 70 degrees).   It also says your sensor should only read as low as 9 degrees when it maxes out at 5V, and should hit a peak of 114 degrees at 0V... Just as a heads up if you were going really cold places, or wanting to be aware when temps really go up with it.
    • you, sir, are a prince. good on ya.
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
