Your spaced out :P
When my car is going I'll organise a cruise... Once Jarrad has moved and all the motorsport events are done (pretty much all of August) I'll
Organise a BBQ meet up too, just for something different, try keep the Newy scene kicking :D
Oh, and we have a new skyline and member coming next week, Jack my next door neighbour loved my beast and has gone down to Nowra to pick up a 32gtst.... Good times ahead!!
Great work!
heres a pic i took yesterday whilst over at stockton... alot of potential for some good shots over there for meets etc...
Awesome shot mate!! It's a good location with potential... Just was the car after being near sand and salt etc ;)
Cheers mate... Yea she is probably due for a wash. Do you think it actually hurts the car that much driving it near the ocean etc?
Unless it was parked there regularily I wouldnt think so, but I'd hose the car anyway to be cautious...
Yea makes sense.. Will give it a wash through the week if there is some decent weather.. Need to clean up the inside abit also..
Hey Guys, I finally got that disc replaced from our Meet Up and posted the last of the pictures -
http://www.skylinesaustralia.com/forums/topic/404240-newcastle-meet-up-wrap-up-thread/page__st__160__gopid__6454592#entry6454592
I know a few wanted copies so ill make some soon ;)
Anthony, definatly a great location for a group of cars pics!!
Yeah its a good spot... Should be able to get a location on the grass to get all of Newy in the backdrop? Not sure if we would need to run it by the council first though?
Yea i was thinking of getting some with newy in the back ground, i think there are plenty of spots for us to go etc.. but yea, nobbys in the backgorund works well. took some shots from the boat ramp facing towards korangang, showing the real newcastle ha... but they all turned out bad due to wrong settings on the camera unfortunately....
Yeah I've got a bit on too but may organise a meet for the guys anyway... We have a few new cars joining us on the next one :yes:
Waiting in coilovers and a few other bits mate :/ but found them cheap so it's worth the extra week wait
What coilovers did you end up getting Matt?
yea sounds like a plan mate. i will do my best to come along if im not in the snow etc..
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
    • I know on some cars it's explicitly endorsed in the service manual but a lot of them it isn't which is what gives me pause. I know a lot of cars also have you jack up the car by the radiator core support which is a lot easier to get to than some crazy deep section of the front subframe. I'm just reluctant to find out if any of that is really safe to do if not listed in the service manual. The FK8 has even the R-chassis beat in this regard, the front subframe jack point is almost fully behind the front tires and is surprisingly recessed into the car.
    • I've been doing it for longer then I can remember and on pretty much every car I've owned without any issues.  Jack on a tow point (or under the rear diff), jack stands under control arms/other beefy suspension component is my go to if I'm not using the quick jack.
