Glad the week is over
Really should wash the car and make an effort on the interior but CBF at the moment
Shit thing this morning though is I sat a full mug of coffee on the console this morning while I grabbed the work boots, hoped in the car and promptly knocked the coffee all over the passenger seat :(
5.30 on a weekend ESP on a Sunday is just wrong unless you are getting home at that time then it's all good
that actually might be a solution ant --> go out, go straight to airport from town - sleep on plane or in the conference
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
