lol - it was regarding Ant's pods...
I had a question about them ...then i thought...I have 3 different intake boxes and a set of pods in my garage, I don't really need another intake lol.
ha probably a suitable amount then! i will be posting a for sale add tonight.. and probably tyres too as i just got some pics.
Hello look forward to seeing you again. :action-smiley-069:
Will be good to say G'day again :D
Maybe you should get a spare gearbox as well just in case
Yeah Jim said i need to learn to be mechanically sympathetic as the box is the next weakest link!
Got a HID kit being installed, come clear indicators and maybe a BOV. should be done end of month :D
Please NO BOV...... Clear indicators and HID are epic win though! :yes:
agree, stock gtr bovs to the job just fine!
Good for 400kw+ ive heard!! So please keep them and spend the money on useful upgrades :yes:
Be good to catch up for a cruise once i am back on the road.... My clutch will take 500km to bed it apparently so once its going i reckon thats a weekend lol
then skids on my stockies :D
Hahaha skids will be on the menu! On a private track of course!!
I'm not allowed to side step the clutch with this new thing :/ he said it makes gearbox go BOOM!
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
