Yeah I want got brakes for sure.
Hey ant if you do come round to help with my car wanna extend our date and check out that white 33 in Maryland got shits n gigs?
Be good to start looking at a few to get a feel for them.
All... By... My.... Sellllfffffff
Don't wanna be...
All... By... My... Selllllffffffffffff.
Im all alone.............
Shutup Donkey!!! :laugh:
Farkkkkkk!
Not Gunna lie, could be my fav colour in 33
http://carphotos.cardomain.com/ride_images/1/973/1441/2430720026_large.jpg
Team yellow ant dog!
I drove a yellow 34 and really couldn't handle the site of the colour, Ant pulls it off nicely though especially with the black.... But that 33 looks pretty good.... Not sure why but the gtt yellow just doesn't work!
Gear ratio 8.35 to 1..... Maybe I should do that to the skyline.... Limiter in 5th in a school zone FTW lol
Hating on team yellow eh? Haha
It is a very bright colour, and would have to agree, haven't seen to many yellow gtts that look really good.
The gtt yellow is doing it wrong!! Dunno why tho
It just doesn't look good
I can help come inspect the car if need be....
I have a lot of knowledge with regard to inspecting cars for accident damage etc...
Also, anyone heard of the Nismo 400r....they are a collectible classic so command a massive premium in Japan
if i got a 33 gtr in yellow wed need someone to get a yellow 32,
come on boys, whos selling there gtt??
Bring some paint and we will tackle Jacks?
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
