I have some old stereo gear i wanted to put into my car but still enjoying the sound of spool etc on the odd time i get to drive the damn thing :dry:
there links to google images, they dont work?
Yeah they work but it required me having to click on it and that is WAY more effort that i was willing to put into it :P
what sound system?... taking a weight saving page from benji...
Lol.. Ask Benji what you can do to save weight in your 1990's/ 2000's non accident Japanese nostalgia vehicle..
I just have some Sony cd player clarion speakers and some rubbish amp..
Thinking of ripping them out for weight reduction.. Lol..
When I had my S13, I was planning to order some quality Pinoneer sound system stuff.
They produce good quality gear from what I've heard....
If you get a double din headunit, you can run the HKS camp system off that :woot: ...which eliminates the need for gauges.
My factory Cd player has locked me out and wont accept the pin code I found in the manual. Faceplam.jpg :domokun:
win!!!!
the last owner striped the sound system out of mine...i just never bothered to install a new one lol. But....i do plan to install a car computer and a decent set eventually, but i know nothing about speakers etc
I like the way the last owner thinks.
I am going to remove my boot carpet for Stage 1, Stage 2 required NOT eating 14 pies every time me and Chookie go past Pie In The Sky.............. Stage 3 TBA
Please note, Stage 3 is not for Amatuers and for offroad use only!
DIF - can you modify your signature to remove/modify the c*ck word in your sig - my net nanny at work freaks out whenever you post
:laugh: WTF is a net nanny?
Stage 3 is taking a dump before going for a drive (typically deletes 1-2kg of mass)
Or in your case having any sort of coversation and dribbling 1-2kg of shit :P
Done..
Bloody nanny goats...
Quality post for weight saving right here guys!
Net nanny - stops people browsing porn and bad things at work - ours is actually called web Marshall
Btw I've had to switch to my phone
If mine did that i would have nothing to do but work! That would be super gheeeeeeeeeeeeeeeeeeeey!
Do you use the mobile version or full version on your phone? Mobile version has a few little bugs that shit me!
Lame!!! If I want to browse sexy ladehs at work wastelands or shock mansion lol..
thanks DIF :-)
NP
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
