Benji the fastest road registered cars time is 1:05. It's a fully worked integra.
You will not get 1:08. Youll struggle hard toget 1:15
And considering you've driven your car once I think you might get 1:18
They vary a little the 17 inch is 400!
Pm Cpd for prices if your a nsw member :).
If your not pm him anyways and say you'll be joining soon the price pays for your membership, not to mention events cheaper
J-Rad where you doing the brakes on your car r was that someone else?
Can do them here if you need guys, once my car is out of the way... Should be on the deck by Sunday night
Probably my garage. I'll have to check out how much space is there.
Wanna have a brakes day? <3?!
Haha true benji. Maybe WA has a similar thing??
Still get a price. 60 bucks membership surely a bigger discount then that
You'd be surprised..
i'm moving to Perth in bout 3 weeks - im already working there...so a WA membeship is probarly the better option. lol
WA = :no:
No E85 = No fun :P
one of the united stations south of the river was meant to have it - I checked it out this arvo after work - no deal :domokun: :domokun:
I'm going to try to contact someone in united and see if we can get it or at least if there got any plans to set it up over here
Edited by wedge_r34gtr
PM Hanaldo, pretty sure he has done all the research mate!
Hmm yeah Righto, umm I'll let you know when I got em? Maybe next weekend? :)
I want them on for the cruise to bed them in!
Yeah just let me know :) I gotta get mine in too BUT another 3 weeks or so before I get the rotors :( fail.....
Gotta bed that monster clutch in :P
Hahaha very good!!!
Wish I could get rotors... Though... I have gtrs on the brain brah! Since yesterday fark in keen!
Yeah then you will just need an anchor and bow thrusters...
Sigh... Hahaha hvent even got the f**kin thing and I'm already sick of it haha.
The gtrs aren't boats ya fool!
It's still a 33! It's more of a ship I guess as its bigger :P
to be honest i don't really need tires atm -it was just a good price. i'm sure there will be another deal next year
i'll keep that in mind and send him a pm. I'm pretty keen to go green
    • Try looking at Eibacb/H&R springs Thats what Gary sourced for mine.
    • Hey y'all! I'm curious about how y'all go about widebodying your cars. I noticed that when running a square setup, my front wheels are a bit more tucked in than my rear wheels. Not by much, maybe 5-10mm. This leads me to wonder - when I widebody, should I use narrower front flares and wider rear flares? I found a set of 40mm rear flares that I really like, and was thinking of pairing them with some 18mm front flares, but I don't want the car to look strange. How have others done this? Note, I'm in a sedan. Thanks!
    • And if it was anything other than an auto tranny part, it might be a problem. But seeing as all auto trannies belong in the recycling bin, it's fine.
    • I have an R32 Fenix rad. It is good.
    • All the schemas I can see, indicate your typical setup of ATF 'cooler' (read: heat exchanger) in the bottom radiator tank..ie; https://nissan.epc-data.com/stagea/wgnc34/5413-rb25det/engine/214/ ...but I can prattle on a bit here. These trannies have a thermistor in the sump ~ the TCU reads this and 1. bumps the line pressure up when the ATF is 'cold' and 2. prevents the TC lockup clutch from operating, until the ATF comes up to minimum operating temp (keeps the ATF 'churning' through the TC so it heats up quicker) -- trigger point is around 55C. In these conditions, the engine coolant temperature rises faster than the ATF temperature, and also helps heat the ATF up, which is why it's best to think of the in radiator tank setup as a heat exchanger ; the heat can flow in both directions... ...with these trannies, the 'hot' ATF comes out the front banjo bolt, flows through the cooler/heat exchanger, and returns to the box  via the rear banjo bolt. This gets a mention, due to the wildly different opinions wrt running auto trans fluid coolers ~ do you bypass the in radiator tank altogether, or put the cooler inline with the in radiator tank system...and then, do you put the additional cooler before of after the in radiator tank system?... ....fact is the nominal engine operating temp (roughly 75C), happens to be the ideal temperature for the ATF used in these trannies as well (no surprises there), so for the in radiator tank system to actually 'cool' the ATF, the ATF temp has to be hotter than that...lets say 100C -- you've got 25C of 'excess' heat, (slowly) pumping into the 75C coolant. This part of the equation changes drastically, when you've got 100C ATF flowing through an air cooled radiator ; you can move a lot more excess heat, faster ~ it is possible to cool the ATF 'too much' as it were...(climate matters a lot)... ...in an 'ideal' setup, what you're really trying to control here, is flash heating of the ATF, primarily produced by the TC interface. In a perfect world, wrt auto trans oil cooling, you want a dedicated trans cooler with builtin thermostatic valving - they exist. These should be run inline and before the in radiator tank system ~ when 'cold' the valving bypasses the fin stack, allowing the ATF to flow direct to the in radiator tank heat exchanger, so it works 'as intended' with helping heat the ATF up. When 'hot' (iirc it was 50C threshold), the valving shuts forcing the ATF through the cooler fin stack, and onto the in radiator tank heat exchanger...and you sort of think of it as a 'thermal conditioner' of sorts...ie; if you did cool your ATF down to 65C, the coolant will add a little heat, otherwise it works as intended... ...the 'hot' ATF coming from the front bango bolt, is instantiated from the TC when in use, so all/any flash heated oil, flows to the fluid-to-air cooler first, and because of the greater heat differential, you can get rid of this heat fast. Just how big (BTU/h) this cooler needs to be to effectively dissipate this TC flash heat, is the charm...too many variables to discuss here, but I just wanted to point out the nitty-gritty of automatic trans fluid coolers ~ they're a different beastie to what most ppl think of when considering an 'oil cooler'... /3.5cents
